That evaporate or fan is either running constantly or rapidly pulsing on and off. This is the fan that blows the cold air from the freezer to the fridge. I've done some research online I ordered an adaptive control module with a new wire harness. The refrigerator is still working. I installed the new adaptive control module with the wire harness after watching several videos online. I know it's installed correctly. After installing it the fridge doesn't work at all. Checked all connections. Plugged in tight. Great! Put the old adc back in with the old harness. Works as before, with a pulsing evap fan. Defective part or did I miss something?
Just wanted to let anyone out there know what the issue was. Turns out it was a bad adaptive defrost control. The first unit sent to me was DOA on arrival. Recieved another one today. Installed and now the fridge is back to normal. Lesson learned, new parts can be broken. And this is not the first time this has happened to me.
