gnnbtrn
#1 Posted : Monday, July 18, 2016 1:34:36 AM(UTC)
gnnbtrn
Good morning.
My fridge KSRS25I compressor is running hot. No clicking noise. The freezer is freezing, but fridge area is not so cool. The air is blowing from freezer into fridge area. I have extra fan blowing overnight to compressor, but it did not help. Still hot.
Also, the wall between freezer and fridge is warm
What could this be?
charliesmith
#2 Posted : Monday, July 18, 2016 3:35:17 AM(UTC)
charliesmith
I think the problem is most likely either frost-clogged evaporator coils or a stuck or broken evaporator fan.
gnnbtrn
#3 Posted : Monday, July 18, 2016 3:47:36 AM(UTC)
gnnbtrn
Thanks, but the fan is blowing. I mentioned that to help with the airflow I have placed box fan behind the fridge, but it did not help much.
There is no frost buildup inside freezer
How do I check if evaporator coils are frozen?
gnnbtrn
#4 Posted : Monday, July 18, 2016 4:13:16 AM(UTC)
gnnbtrn
I was thinking about different fan on the back of the fridge.
I took inside freezer panel off and evaporator fan is good, also there is no buildup on coils.
but compressor still runs hot and the refrigeration area is not cooling enough
