AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore Super Capacity 3.5 Won't Start/Just Buzzes
Kenmore Super Capacity 3.5 Quiet Tumble Action Wash Easy Access washing machine buzzes loudly after hitting start button but does not start. It shows that there is not a load in there when there is. "Load Washer" light stays on (all other lights appear normal). The control panel seems to be working fine. I have removed it and everything looks okay. The door appears to be shutting fine. I have also removed the back panel and instected the wiring, etc. and have found no issues. The water is connected and turned on. Any ideas?
When I said, "load washer" light, I meant "add garmet" light. Normally, just the "washing" light stays on. The start light will flash while the buzzing is occuring also. I also forgot to mention that I checked the hoses for clogs as well and they were clear.
Washer Repair
