I change the motor of the timer of my dryer and now it run backwards . What happen ?
I change the motor of the timer od my dryer and now run backwards
I change the motor timerb of my dryer and now it run backwards
The timet dryer is runing backwards
Yes, I have found a few of these timer motors that operate in the opposite direction. If you are need of a timer motor I have some but would need to see a picture of your defective one and any other details . Also some of these timers are made with a dual gear drive output and some with a single gear drive output. My e-mail address is as follows: jaybird@mtco.com
