My whirlpool washer will only fill with water and make a humming sound. We have changed the lid switch and motor. Any help or advice would be greatly appreciated.
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
If you have installed a new motor and you still get a humming sound the reason could be the start capacitor is bad. You can find one here @ Whirlpool WP8572717 Capacitor - AppliancePartsPros.com Does it drain and spin? Also another reason is the transmission may be locked up.
It will fill with water and hum only. Thank you for your help. I will let you know what happens next.
It was the start capacitor. Thanks for the help.
Thank you for the update and for using appliancepartspros.com glad we could help!
