Maytag washer completes every cycle except spin
Hi Brandon
Can you give us a detailed description of what happens. Does the machine fill, agitate and drain and then come to a halt? Does the timer continue to run? If you mannually advance the timer (I am assuming you have a timer) will it spin or can you move it to rinse where it will start up again?
Also, please post your model number, and let's see what we have.
thanks for your response i will have to get the model number because the washer is presently in storage then i will send all information.
hey its brandon again i have a maytag performa model # pav2300aww will agitate,rinse,does drain good,but will not do finall spin have already put brand new timer on washer but did not help
Hi Brandon
This is a bit unusual so I have to ask some more questions.
1. Does it spin after the wash cycle but not spin after the rinse cycle?
2. Does its failure to spin occur in all wash cycles.
Since you have replaced the timer, which would have been my first suggestion we are going to have to look a little harder for the problem.
Remove the front panel and look for white plastic shavings on the bottom near the tranny. If so, you have a worn snubber ring. Post results.
thanks for the reply i will have to check this out not sure about the spin after wash cycle i know it want spin after rinse cycle this washer belonged to my mother she gave it to me to fix if i can to try and save a little cash i will have to do a test run on the washer
i will do this as soon as possible and get back with you thanks for the reply
