LTK
#1 Posted : Monday, June 13, 2016 6:33:31 AM(UTC)
LTK
I have a Jenn-Air range:
[FONT=&quot]Model JES8850BCB[/FONT]
[FONT=&quot]Serial 13769522JP[/FONT]
[FONT=&quot]The left front element is not working and the hot surface indicator lamp is always on. The element inner and outer resistance measurements checked out okay at 37 and 31 ohms respectively, so I replaced the custom infinite switch with part number W10185286 (updates from 74011596). However, I still have the same symptom. The element has a thermal sensor in it and when I check the resistance, it is open, so I suspect that is the issue. Based my research, it looks like the sensor is not sold separately, so I would have to buy the entire element assembly. If this is the case, what is the part number I should order?[/FONT]
