I have a GE pss26sgpass fridge. I replaced the dispenser control board because I did not have water through the front dispenser, and auger would not turn.
I then replaced the main board, still no water or motor auger movement. I am not getting line voltage to dispensor water solenoid. I couldn't see any voltage on the circuit board on the Solenoid or Auger pins (I read I should be able to read mains voltage between J7P9 and J7P3. I am reading 0.
Lights work on dispensor board.
Any Suggestions?
(Attached: pics front and back of burned old main circuit board)
[IMG]https://www.flickr.com/photos/asegal/27357111340/in/dateposted-public/[/IMG][IMG]https://www.flickr.com/photos/asegal/27600922416/in/dateposted-public/[/IMG]
Attachments are here if not visible above AJ0000 attached the following image(s):
