Hello Everyone,
I have a GE Washer from which water drips even after the washer has been turned off. From searching this forum, it seems like the most common reason for this problem is an issue with the inlet valve. I believe for my model, I require part number AP3861119. If anyone has any other suggestions before I order this part or any diagnostic tests I should run to ensure this is the issue, please let me know.
Thanks!
