Hello,
My Dacor range has started to display an error code, F32, periodically. I disconnect power to the range to reset but the error code returns with constant beeping within a couple hours (and sometimes in the middle of the night!). All of this with the Range not in use.
From quick internet searches I've found causes for a F32 error from board to board communication to keypad problems. This doesn't really help because the guts to this Range is basically two boards and a keypad. I'm not sure what to replace at this point. All of the keypad buttons seem to work still. Can you offer any advice where to go from here?
Best Regards
Wow, came back for yet another problem with my POS Dacor oven and found my old thread. To answer my own question, the F32 error was caused by a faulty keypad membrane. I replaced the membrane and beeping with error code is gone. But enter new problem. Oven now shuts off by itself for no reason and with no error codes! Starting new thread.
