Jeff Winholt
#1 Posted : Sunday, May 22, 2016 5:25:10 AM(UTC)
Jeff Winholt
The washer fills and empties, but it doesn't agitate of spin. The flashing light on the motor is on for 1 sec then off for 1 sec, normal standby mode. HELP!!
Jeff Winholt
#2 Posted : Friday, May 27, 2016 5:36:27 AM(UTC)
Jeff Winholt
It turns out that the motor needed to be replaced. Difficult decision to replace the motor, because the indicator light on top of the motor was flashing 1 sec on 1 sec off, indicating normal standby mode. I tried it as an act of desperation, and voila, the problem is fixed. So I have to ask myself if it is worth spending $220 to repair a 10 yr old washer. If it lasts another 10 years, then it was worth it, if not then perhaps not.
