AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Kenmore Dryer Won't Shut Off; Gets To Cool Down and Gets Stuck
Hello,
I have a Kenmore model 110.69422801 that will not shut off after a timed dry. The timer will run all the way through the cycle to the cool down position, and then stop moving. The dryer will continue to tumble and supply heat indefinitely unless the door is opened or the timer is manually turned to the off position.
I saw one post that had the same problem. However, the fix for that one was replacing a resistor near the timer assembly, which my dryer does not have. Please help! Thanks in advance.
-Brandon
Dryer Repair
