BigEd313
#1 Posted : Saturday, May 21, 2016 11:39:33 AM(UTC)
BigEd313
I installed a thermal cut-off kit in the dryer because it was getting way too hot when running, really overheating. After a bunch or research I decided that was the issue but......now as soon as I plug the dryer in the heating element turns on and if I push the start button it just hums. Any advice?
BTW, I have 10 ohms across the heating element
BigEd313
#2 Posted : Saturday, May 21, 2016 11:49:57 AM(UTC)
BigEd313
I re-installed the original parts and now it is doing the same thing, heating up as soon as it's plugged in.
I did, however, pop the breaker when I first installed the new parts. I had plugged the wires into the thermostat itself (not thinking) instead of one in the thermostat and one into the heating element and bridging with the jumper....
BigEd313
#3 Posted : Saturday, May 21, 2016 12:42:50 PM(UTC)
BigEd313
Well, I kept digging and found only half of the element is heating, now I need an element too......
BigEd313
#4 Posted : Sunday, May 22, 2016 7:01:27 AM(UTC)
BigEd313
I guess I'll have a new dryer minus the shell and switches when I'm through.
Heat element won't shut off when door open (Dryer Repair)
by Jack B 7/30/2015 7:46:02 AM(UTC)
