faunwin12
#1 Posted : Saturday, May 14, 2016 6:20:49 AM(UTC)
faunwin12
My Mom has a Roper top fill washing machine that will fill with water and then do nothing else, won't agitate, drain, or spin. It does make a humming noise on those settings, but that's it.
We already replaced the lid switch assembly, and then replaced the timer, still no luck. I should note that my Mom says that at the end of the last load that washed, she heard the brake kick in and then a loud thump or pop sound.
Any help would be appreciated. Also, you can't manually turn the washer tub or the agitator. Hmmmm.
allen9258
#2 Posted : Tuesday, May 17, 2016 8:53:19 PM(UTC)
allen9258
try pulling the water pump to make sure that there is no piece of clothing that cause the pump to stop the motor from running if so then remove the clothing or replace the water pump hope this helps
