Kitchen Aid Built In KSSC48QTS03: Ice Dispenser Door Won't Close? The Ice Dispenser Chute door will no longer close all the way, I am assuming it is the motor, but it is letting warm air in and leaking if I don't shove a towel in to seal it, the warm air is also affecting the crisper drawers in the fridge, I have looked everywhere and there is no information on how to access the motor or door. The dispenser is recessed mounted with no fascia or access from the outside of the door, I have looked inside the door and it still seems hard to access, so I wondering if anyone has experienced this fridge? If I can gain access I would like to replace: Motor & Bracket Assy-Ice Door Whirlpool WPW10546285 Motor & Bracket Assy-Ice Door - AppliancePartsPros.comIce Dispenser Chute Door Whirlpool WP2180353 Ice Dispenser Chute Door - AppliancePartsPros.comAny help is appreciated
