Nutforbriggs
#1 Posted : Thursday, April 21, 2016 11:42:33 AM(UTC)
Nutforbriggs
Dryer within last three weeks stopped shutting off in automatic cycles only. Timed dry functions fine which begs the question--is half of the timer out? If not, what should I look for??
Thanks in advance
Tom
Appliance Medics
#2 Posted : Thursday, April 21, 2016 11:50:49 AM(UTC)
Appliance Medics
Is it drying the clothes? Clogged venting can attribute to the auto side running forever as well. If the venting is clear check for a metal sensor on the inside of the dryer somewhere ( looks like 2 metal bars on a plastic bracket) and make sure there is not anything metal touching the 2 sides together. Such as a coin or piece of zipper ect
Nutforbriggs
#3 Posted : Monday, April 25, 2016 2:32:43 PM(UTC)
Nutforbriggs
Hi again...
Nothing touching any contacts. Venting clear...thoroughly cleaned ductwork and dryer a while back...not sure where to go next. It is drying clothes; just won't shut off. I did notice today that after running over an hour and a half it's not calling for heat and there was still a little dampness on the load. Was set to automatic side...very dry setting.
HELP, please!!! I don't want to just throw parts at it to see what sticks...
:confused:
Nutforbriggs
#4 Posted : Thursday, April 28, 2016 12:51:14 PM(UTC)
Nutforbriggs
Still need help on this dryer...PLEASE!!!
Appliance Medics
#5 Posted : Tuesday, May 10, 2016 12:35:50 PM(UTC)
Appliance Medics
Sorry was on vacation. Try running on auto for a load with venting off. If it works it's the vent that is the problem if not its got to be timer related but can't know for sure without being there
Guest (5)
