Gildorg
#1 Posted : Tuesday, April 19, 2016 7:05:11 PM(UTC)
Gildorg
Hi There,
Is there a keypad sequence that can temporarily reset the dryer?
I understand that some dryers do have these sequences...
I understand that Code 63 is the heating element.
Thanks you.
Appliance Medics
#2 Posted : Wednesday, April 20, 2016 3:53:13 AM(UTC)
Appliance Medics
The only safe way is to check and make sure your element is not bad if it's the model I'm thinking of it has a dual element and typically one side goes bad so it heats a tiny bit then stops
Electrolux Dryer Error Code 63 Repair (Dryer Repair)
by ricco7 10/10/2014 8:11:56 AM(UTC)
