Our washer gave us thd wd message. We took off the front panel and searched all hoses for obstructions and found none. We put it back together, and now it will not run through any cycles. Would a bad pump cause it to not run?
Wd? Haven't seen that yet but a drain pump that is bad can cause your washer not to function.
Samsung is the worst in washing machine segment
