MAKODOG
#1 Posted : 9 years ago
MAKODOG
Hi, I am having no luck in finding the part for a new door latch for my THERMADOR oven, any ideas what to do ? Otherwise I am stuck buying an entire new unit but only the small latch is broken.
THANK YOUUUUU!! I need to find 6486733.
Appliance Medics
#2 Posted : 9 years ago
Appliance Medics
00486321 this is the switch bank part number. Not sure if it is what your looking for or not. Is it the door side of the microwave or machine side?
QuinnKurk
#3 Posted : 9 years ago
QuinnKurk
What issue are you having? I gave a 10 yr old Thermador microwave oven and the door would close but the light would stay on, and the microwave would not operate. It wasn't a faulty latch but rather a bad switch. I replaced the switch and now when the door is closed, it works properly.
I had trouble finding the switch I needed but called a local Thermador dealer and he gave me a cross reference number for the switch. I found it online easily after that.
Good luck!
