Jpleech
#1 Posted : Sunday, April 17, 2016 4:59:43 PM(UTC)
Jpleech
Have an older roper electric dryer that has been giving me fits of late. Dryer runs 2-3 minutes before shutting off. I can restart the dryer immediately after it stops but it still only runs 2-3 minutes. Dryer seems to be heating fine and gets warm. Dryer shuts off on all three heat settings, timed dry, sensor dry and no heat dry.
Suggestions?
Appliance Medics
#2 Posted : Sunday, April 17, 2016 6:13:32 PM(UTC)
Appliance Medics
Due to the age and sound of complaint I'm going to have to point towards a motor on this one. Sounds like it may be overheating and cutting off on its overload. When it stops are you able to start it back up immediately or does it take 30 seconds or so to work again? If so and after a time and you hear a clicking sound that could be the ove r load reseting once it cools down
Jpleech
#3 Posted : Monday, April 18, 2016 3:50:26 AM(UTC)
Jpleech
I sat there several times yesterday, didn't touch a thing on the dryer and pushed the start button immediately (within 1-2 seconds) after the dryer stopped. The dryer started without any difficulty and the shut down 2-3 minutes later. could it be some sort of relay?
Appliance Medics
#4 Posted : Monday, April 18, 2016 5:45:51 AM(UTC)
Appliance Medics
I do not see any kind of relay involved on this model. There seem to be 2 possibilities I can think of... bad centrifugal switch in the motor, where for some reason it may be broken or temporarily failing, now this comes as a motor assembly. Or number 2 would be a bad timer, could have a couple dead spots in it causing it to fail every so often.
Jpleech
#5 Posted : Monday, April 18, 2016 6:47:39 AM(UTC)
Jpleech
Can either of these be tested. Like you, I'd be quick to identify the motor but the situation does not present as bad motors do, given the fact that it will start immediately after shut down. Question whether it's the timer since it seems to fail pretty much wherever it is set.
Appliance Medics
#6 Posted : Monday, April 18, 2016 6:55:30 AM(UTC)
Appliance Medics
To test the timer sometimes they give you a contact chart in the schematic for the machine found in the console. It's normally tested by continuity and machine the contacts with the chart and whether they are open or closed at certain timer positions. The way the motor fails you'd have to check voltage on your motors centrifugal switch. This also requires a schematic and can be fairly difficult. It is best to remove the drum and alligator clip leads to the terminals if possible to find out which side we are losing voltage from.
Guest (5)
