Lock light next to the 3 is on. when I try to shut the machine down the light flashes 5 times then goes back to solid. None of the controls work. Shut the power off to the unit for 24 hours with no effect. Is there a code to unlock the panel? I read on another post to hold down the "Heat dry" button for 5 seconds...Nope. Took the panel apart to check for damage or water, and it was clean and dry. Anyone have the secret?
