cvm
#1 Posted : Wednesday, May 20, 2009 6:55:48 PM(UTC)
cvm
Dryer (stackerdryer) will start and finish cycle but will not dry clothes all the way. Always need to run cycle 2-3times for it to dry clothes completely. What can be the problem? Please help
kayakcrzy
#2 Posted : Thursday, May 21, 2009 4:11:27 AM(UTC)
kayakcrzy
Check the vent to the outside and be sure that it is clear. If you are not sure then, pull the unit away from the wall, and take the vent hose off at the dryer, and run a cycle, and see how it works. If it works fine the vent is clogged, if not a operating thermostat would be a good place to start. Tom ApplianceEducator.com
