Leroy1924
#1 Posted : Monday, April 27, 2009 8:19:56 AM(UTC)
Leroy1924
I have a Maytag coin-op dryer that wont shut off unless the door is opened. The new timer I installed works fine but when it runs out of time the dryer keeps running. I hve tried everything that I can think and nothing seems to work. ANY IDEA'S ??
#2 Posted : Monday, April 27, 2009 10:55:10 AM(UTC)
I would check the start switch. If you do have the wiring diagram and can post it - it might help.
Here are the breakdown diagrams and Replacement parts for MAYTAG GDE18CS | AppliancePartsPros.com
Leroy1924
#3 Posted : Wednesday, May 20, 2009 6:53:23 PM(UTC)
Leroy1924
I replaced the switch and the timer still won't stop the dryer from working. Any more idea's?
#4 Posted : Wednesday, May 20, 2009 9:01:41 PM(UTC)
I can not provide more accurate advice without the wiring diagram. Post it if you have it.
Leroy1924
#5 Posted : Thursday, May 21, 2009 3:48:35 PM(UTC)
Leroy1924
I replaced the switch and the timer still will not stop the machine from running. Any other suggestions? I feel like I have tried everything.
