Hello All and hoping someone can help.
About a week or go, the Dishwasher completely died on me where it would not function at all - no lights would come on and the unit was completely unresponsive. After some research, I discovered that the cause could be a blown thermal fuse and sure enough, I replaced the fuse and the Dishwasher came back to life!
However, I am now noticing that the dishwasher will stop during the cleaning program and the stop/resume light will be flashing away waiting for it to be pressed in order to continue which it does, but I have to do this several times before the full cleaning cycle completes.
Does anyone know why this is happening? Is there a special reset that needs to be done which I have seen posted for other units and if so, can someone kindly provide the reset sequence that I can use for this machine?
Appreciate any help/advice in advance...
Cheers, Vin.
BUMP! Anyone...?
Cheers, Vin.
