David _F
#1 Posted : Monday, March 14, 2016 9:53:33 AM(UTC)
David _F
The washer high speed rinse cycle will not engage. The entire washing cycle operates normally until the final rinse where the speed maintains normal and does not engage into high speed. There are no errors popping up and a new clutch assembly and latch lock switch were installed, but neither remedied the issue. Any idea what could be causing this?
Thank you.
