markusm
#1 Posted : Thursday, March 3, 2016 7:17:17 AM(UTC)
markusm
Recently moved my daughters' Maytag dryer from storage to her home 1 and a half hours away. We tried to be careful during the move but now the gas dryer will not heat. All other functions seem OK. After perusing this website I see several parts that may be suspect (gas valve coils, flame sensor, igniter, etc.) My first question is how do I get into this thing? After looking it over I see that the two sides and back shroud are all one piece. Is that how I get inside or am I missing something? My second question is: once I get inside will I be able to operate the burner to see exactly what's going on? I can't even find a spyhole anywhere to see if the burner is lit or if the igniter is trying to light it.
markusm
#2 Posted : Monday, March 7, 2016 3:53:03 AM(UTC)
markusm
No replies to my query but I'll report what I discovered in case it's a help to others. The front of this Maytag dryer comes off easily. Remove two screws (one in each hinge) that hold the hinges to the dryer, then lift the door and hinges up slightly and slide them out of the slots. On the opposite side of the front shroud there are two screws as well. When you remove them you can tip the front shroud out at the top and lift the whole thing up off the tabs at the bottom. Now the gas valve and burner and other components are accessible.
What I discovered after much head scratching and investigating is that sometime during storage an insect had built a nest inside the gas pipe clear up by the gas valve. After running a wire through the pipe and blowing it out with compressed air I had unrestricted gas flow and the dryer worked.
Now, although the dryer fires and lights, the burner doesn't seem to stay on very long. It stays on 15 to 30 seconds then goes off for a minute or so before coming on again. This continues for as long as the dryer is running. Having never owned a gas dryer I don't know if this is normal but after drying a load of clothes for an hour and a half and them coming out still damp I think not.
Some of the other parts that I understand will prevent the dryer from heating properly are the dryer cycling thermostat, the dryer gas valve coils and the flame sensor. My question is: are these components testable with a multimeter and if so, how?
markusm
#3 Posted : Wednesday, March 9, 2016 5:31:55 AM(UTC)
markusm
In hindsight I feel foolish that this problem buffaloed me as long as it did. The house we moved the dryer to had sat vacant for several months. The dryer vents from the laundry area into a duct in the crawlspace and then out through the foundation wall. Critters had packed the duct with insulation and other nest material. Once that was cleaned out the dryer ran like a champ. They gotta breathe, guys.
