AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Replacing washer door glass without changing frame
We broke the glass on the outer door frame while moving the washer. We ordered a new washer door frame which includes the glass, but when it arrived, the frame was a different color gray than our current washer and dryer (we apparently need the graphite gray which is no longer made and we cannot find being resold anywhere). Is it possible for us to pop off the current graphite gray frame and replace the original broken glass with the glass we received in the new frame, and then use the new glass and original frame together to fix the door, or are the frame and the glass on that part one piece which cannot be separated? Thank you for any help you can give.
Washer Repair
