I need to replace the outer housing of the refridgerator. I have a son with special needs and he dented the left outside panel of the fridge. I rent and I am moving out of my apartment at the end of March and i wanted to fix what he damaged. I don't know if it's even possible. I can't find the outside housing anywhere. I am a single parent (female) and money is limited so I am looking for the lowest cost options. Please help me if you have any information. I tried everything i knew first before I asked for help.
Originally Posted by: JV123 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I need to replace the outer housing of the refridgerator. I have a son with special needs and he dented the left outside panel of the fridge. I rent and I am moving out of my apartment at the end of March and i wanted to fix what he damaged. I don't know if it's even possible. I can't find the outside housing anywhere. I am a single parent (female) and money is limited so I am looking for the lowest cost options. Please help me if you have any information. I tried everything i knew first before I asked for help. JV123, If this is the left side panel of the refrigerator, basically it's not repairable ... It would be like a dent in a car fender, pull, "bondo", prime and paint, like a body shop. If it were dents in the door, then the doors could be replaced. Hopefully the landlord will cooperate and understand the circumstances.
Thank you. That is what I was afraid of. Fortunately I did find the same used replacement refridgerators for $275. This is way more affordable than having to buy a new one.
Originally Posted by: JV123 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you. That is what I was afraid of. Fortunately I did find the same used replacement refridgerators for $275. This is way more affordable than having to buy a new one. JV123, You're Very Welcome !!! Wish we could've had better news for you, but some things just can't be repaired. Great that you could find a used replacement refrigerator, pretty reasonably priced. Good Luck and Thanks,
