Elizbetsy
#1 Posted : Monday, February 1, 2016 11:29:18 AM(UTC)
Elizbetsy
I have a LG model WM0642HW and has been giving me the OE code, we have cleaned out all the drain hoses and replaced the pump and the machine still gives the OE code. We than replaced the control board but are getting the same error code. The problem occurs at 37 minutes rinse and spin cycle. Sometimes if you thump the machine it will start running again? What would be causing this problem? Thanks
Millersix
#2 Posted : Monday, February 15, 2016 6:03:36 PM(UTC)
Millersix
You have been a member since:: 8/26/2012(UTC)
I am having the same issue but on model WT1101C. I've checked the drain and drain tube for blockage, I've even tried a different drain location. I've removed the pump and tested it. The pump works. I cannot find a diagram so I am not sure if the control board is next or something else.
Where did you find the parts for your washer? I was very surprised I couldn't find anything on APP for my unit. In fact I don't see much on LG washers.
Thanks,
Miller
Elizbetsy
#3 Posted : Tuesday, February 16, 2016 3:20:30 AM(UTC)
Elizbetsy
I replaced the control board and the pump both and still have this problem. I purchased the parts from www.************************.com. They offer a 365day refund on the parts if the new part does not fix your problem. For the moment I have the washer pulled out about 8 inches from wall when it stops running, I lean the washer back, lifting the front about 4 inches and drop it to the floor. This always gets it working to finish the load. I will take it apart again for the fourth time and just check to make sure there is nothing is between the two tubs.
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
LG washer not letting in cold water (Washer Repair)
by Cgrigson1 4/19/2024 7:34:57 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
LG Washer WM4270HVA/01 incomplete draining OE error (Washer Repair)
by PapawZooKeeper 6/18/2023 12:46:26 PM(UTC)
LG Washer - Rotor and Stator Grinding (Washer Repair)
by Guest 11/30/2022 7:57:29 PM(UTC)
wt7600hwa lg washer (Refrigerator & Freezer Repair)
by Guest 8/19/2022 7:47:52 AM(UTC)
LG Washer Error TE (Washer Repair)
by leonthepc 7/17/2022 1:34:39 PM(UTC)
WT5270CW LG Washer (Washer Repair)
by Gerald Shaffer 7/6/2022 12:59:29 PM(UTC)
LG Washer Drain Pump Noise (Washer Repair)
by Guest 1/28/2022 8:06:10 AM(UTC)
LG washer -Drum not spinning during rinse cycle with Fe error code (Washer Repair)
by Guest 12/29/2021 3:31:30 AM(UTC)
LG washer WM2050CW has water in it after not running for a day (Washer Repair)
by hklein 12/16/2021 4:48:27 PM(UTC)
LG washer tromm (Oven Repair (including Ranges and Cooktops))
by Guest 6/18/2021 5:43:36 AM(UTC)
LG washer not powering on (Washer Repair)
by diyer2018 6/13/2021 6:29:13 PM(UTC)
lg washer power when tub is spun by hand (Washer Repair)
by robin2741 3/29/2021 10:56:54 AM(UTC)
LG Washer WT1101CW (Washer Repair)
by rsrosenberg54 3/15/2021 6:53:23 AM(UTC)
