mark6200
#1 Posted : Saturday, January 30, 2016 2:31:58 AM(UTC)
mark6200
Hi ,
Washer will fill and then timer drops to 12 min and enters a drain cycle and stops. It gives me an oL overload signal at end of cycle even with a small load readjusted . I have run drain and spin cycle and the unit drains then enters low speed spin cycle and seems ok? . It doesn't seem to want to cycle into agitate.
Not a lot experience here with these things but take direction well . Any thoughts ?
sidfink43
#2 Posted : Saturday, January 30, 2016 4:30:34 AM(UTC)
sidfink43
It sounds like your electronic control board is bad, but it is an expensive part and you should consider whether or not you want to put that much money into this machine. These models work great when they have no problems, but are very prone to break down and expensive to fix.
If you do decide to go ahead with the repair I suggest you purchase the part from this site as you can return it if it does not solve the problem, and very few if any other suppliers have that policy.
mark6200
#3 Posted : Saturday, February 13, 2016 7:40:16 AM(UTC)
mark6200
Ok So we had the display pad replaced about 18 mo. ago and you seem pretty sure it 's the control board this time ?
Return policy is that I can return if it doesn't work ?
sidfink43
#4 Posted : Sunday, February 14, 2016 5:42:16 AM(UTC)
sidfink43
Yep, confirm the returns policy when you order
Guest (4)
