tompirkle@bellsouth.net
#1 Posted : Thursday, January 21, 2016 1:33:05 PM(UTC)
I just replaced the spyder in my machine, put it all back together and it does everything but pump water into machine. the pump was working before repairs. Can it go bad during disassembly or reassembly?
sidfink43
#2 Posted : Friday, January 22, 2016 2:13:30 PM(UTC)
sidfink43
Not sure what pump you are referring to. The water enters the machine when the inlet valves open. Check them to see if 110v is getting to them when it calls for water.
