Amana_watt?
#1 Posted : 9 years ago
Amana_watt?
I have an Amanda washing machine that is from 2003, but the hot water valve/tap and hose are from a house built in the late 70's. I am replacing the hoses and washers/gaskets. I noticed the washer connected to the hot water valve out of the wall has a plastic screen/strainer shaped like a thimble. Can anyone tell me the purpose of the thimble-like shape? Also, does this design have any effect on the water pressure going into the machine?
Thank you.
sidfink43
#2 Posted : 9 years ago
sidfink43
That is a rudimentary filter and as long as it is clean and clear it should not affect but enhance performance.
Amana_watt?
#3 Posted : 9 years ago
Amana_watt?
Could you please explain what is meant by enhance performance?
Also, is there a downside with replacing the thimble shaped strainer with a dome shaped metal screen for homes built in the 1970s.
Thank you.
