jesus freak
#1 Posted : Sunday, January 17, 2016 2:25:22 PM(UTC)
jesus freak
As stated. It just runs and runs until manually turned off. No heat.
Thank you!
GLP
#2 Posted : Sunday, January 17, 2016 7:43:28 PM(UTC)
GLP
Sounds like it could be a blown thermal fuse. This typically happens when the dryer becomes overheated, possibly from a clogged and lint filter.
#3 Posted : Monday, January 18, 2016 1:49:44 AM(UTC)
I cannot find a wiring diagram for this unit., so have to do some guessing.
Does the timer advance?
Does it do this in both timed dry and auto cycles?
On many units in auto mode the timer motor gets power through the heating coil when the coil is off.
So it may be just a blown heater coil if the unit advances in timed dry but not in auto.
Unplug the unit and one side of the heater.
Then measure it with a meter.
Most heaters are in the 8 to 12 ohm range.
jesus freak
#4 Posted : Tuesday, January 19, 2016 12:09:06 AM(UTC)
jesus freak
Don't know why the Forum is not sending me notification emails of your posts? I just checked in and found these responses. I do have instant email notifications checked off.
The heating element was broken. I replaced it yesterday afternoon. I'm waiting on my wife's next dryer load for results.
Thank you for your replies. If you can help me with the notifications, please chime in.
#5 Posted : Tuesday, January 19, 2016 12:56:41 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
I cannot do much about notifications as I just volunteer here.
I will forward this on but I do not think there is a moderator for this forum anymore.
jesus freak
#6 Posted : Tuesday, January 19, 2016 5:40:42 PM(UTC)
jesus freak
Originally Posted by: denman Go to Quoted Post
You are welcome.
I totally agree w/ you. I hate when that happens. BTW, the dryer is heating again. 25 years strong!
Guest (5)
