janniiie
#1 Posted : Sunday, January 17, 2016 2:35:18 PM(UTC)
janniiie
while i was cooking, the oven, and stove top elements stopped heating. The warmer elements does work. We have unplugged it and plugged it back in, and checked the breaker and they were OK. What could be the problem? The control board? The lights all turn on to signify that they are "on".
#2 Posted : Monday, January 18, 2016 12:39:47 AM(UTC)
Parts for Frigidaire FEFL79ECD Range - AppliancePartsPros.com
Sounds like a power problem to me.
The control board and warming element run off of 120 volts but all the other elements require the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
