Very loud thumping DIGGA-DIGGA-DIGGA-DIGGA when it tries to stop spinning, eventually stops. Thoughts?
Check out the brakes, they may be hanging up. Also operate it with the cabinet off and the lid switch by passed and look at the support structure and springs. There may be a problem in that area or the tub may be off the pads or the pads may be worn.
Sidfink43, Thank you, I will look at that.
