water101
#1 Posted : Sunday, January 10, 2016 7:21:34 AM(UTC)
water101
Trying to help my father in law hook up his ice maker. Connected the water lines and plugged the power in. Water began to flow and fill the ice tray, issue is water never sopped flowing w]even when tray was full the water kept filling. Not sure which part needs to be replaced but I know one does for sure. If anyone could point me to the part that controls the water regulation that would be great.
Water101
#2 Posted : Sunday, January 10, 2016 10:01:25 AM(UTC)
Parts for Whirlpool GT9SHKXMQ03 Refrigerator - AppliancePartsPros.com
First check for voltage across the water valve.
If there is no voltage then the problem is a bad water valve re: not closing.
water101
#3 Posted : Sunday, January 10, 2016 2:19:46 PM(UTC)
water101
Thanks the issue was the water value. One of the rubber orings was out of place and kept the value open. Replaced the orings and seems to be working now after 3 successful cycles.
Thanks again
#4 Posted : Monday, January 11, 2016 1:12:57 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Guest (4)
