AbbyBrickman
#1 Posted : Monday, January 4, 2016 8:36:24 PM(UTC)
AbbyBrickman
Hello, I have a General Electric Washer Dryer Combo WSM2700HCWWW.
Recently when switched off, there is a slow and steady water drip into the washer tub. I think the water inlet valve needs to be replaced. Found the part:
GE WH13X10035 Valve, Water 115V - AppliancePartsPros.com
But how do you access the water inlet valve?
I found the exploded parts diagram but disassembly is not clear.
There are youtube videos for other washers but did not find one for this model. Any help please? Many thanks!
AbbyBrickman
#2 Posted: : Monday, January 4, 2016 9:06:23 PM(UTC)
AbbyBrickman
This washer dryer is also called Spacemaker, the dryer is on top of the washer
sidfink43
#3 Posted: : Tuesday, January 5, 2016 4:22:19 AM(UTC)
sidfink43
This is actually a Frigidaire machine sold under the GE label cause GE wanted to sell these model but did not want to make them.
See if this link to a service manual works and if so it will tell you how to do the repair.
http://www.emaservicetips.com/pdfs/488_3.pdf
Good luck!
