Hi, I'm a bit of a newbie to washer repair but I've done quite a bit on my cars with the help of the internet. So, here's my problem: On all 3 cycles the washer drains but does not spin during the wash cycle. On the rinse cycle the tub fills probably less than half way with water but does spin. All 3 water temps work okay. The motor is showing no error codes as per HydroWave GE Washer Repair GuideHere is a "diary" of my whites cycle starting on light wash with cold water on the lowest water level setting: After the tub fills: 00:18 Agitation starts 04:02 Rapid agitation begins 04:15 Rapid agitation stops, short pause, and then draining begins. 10:00 Draining stops 10:17 Water refill starts 13:00 Some isolated and not very loud knocking sounds (maybe 3x) ( in timer?) 13:18 Agitation begins 16:00 Rapid agitation begins 16:04 Draining begins (time approximate to within 2 seconds maybe) 16:10 Rapid agitation stops 20:10 Spin begins 20:26 Spin increases 25:20 Spin starts to slow 26:05 Spin stops (the spin will stop with 5 seconds if I open the lid) The only overlap of events that I noticed was at 16:04 when the drain started before the agitation stopped. Otherwise, each step was isolated. Any ideas? Thanks, John M.
