pdusime
#1 Posted : Saturday, January 2, 2016 10:48:16 PM(UTC)
pdusime
Have dryer with newer type wiring plug.
Can I put in older type motor? How does wiring hook up
#2 Posted : Sunday, January 3, 2016 2:46:17 AM(UTC)
Need a model number
Find your model number - AppliancePartsPros.com
And even with that I may not be able to find the info you need.
You need the numbers for the old unit the motor came out of and the model of the current unit so you can check the wiring on both.
It may not be worth the hassle.
Also the mechanical mounting of the motors, the motor speed and the motor's pulley may be different.
changing dryer motor (Dryer Repair)
by dryerrepair 12/4/2008 5:58:15 AM(UTC)
