gunns
#1 Posted : Saturday, January 2, 2016 1:00:58 PM(UTC)
gunns
Top shelf won't clean.
Cleaned chopper assy and flapper valve. All arms and roof spinner and water tubing were clear of debris. Marked upper arm and roof spinner to see if they moved during run cycle. The only thing that moved was the lower arm.
Suspect pump issue. Can it be checked without removal.
Any other possible causes?
#2 Posted : Saturday, January 2, 2016 1:10:16 PM(UTC)
Try adding some hot water after the fill.
Just be careful not to overfill it.
Now if the upper arm moves you know it is a fill problem.
Most likely the filter screen on the input side of the water valve is dirty.
Remove the valve and clean it.
Do not permanently remove it from the valve as it is there to keep crud out of the valve which could cause a flood.
If the screen is clean then ther may be a problem with the valve itself or your water supply.
gunns
#3 Posted : Thursday, January 7, 2016 8:03:01 AM(UTC)
gunns
How high should the water be?
How do you determine when the fill cycle occurs and when it is complete?
gunns
#4 Posted : Thursday, January 7, 2016 8:07:05 AM(UTC)
gunns
I assume the fill valve is the first electrical component that the water flows through from the supply line.?.?
#5 Posted : Thursday, January 7, 2016 8:50:58 AM(UTC)
[COLOR="Blue"]How high should the water be?[/COLOR]
Most units fill to just under the heater.
[COLOR="Blue"]
How do you determine when the fill cycle occurs and when it is complete?[/COLOR]
You should be able to hear it.
[COLOR="Blue"]I assume the fill valve is the first electrical component that the water flows through from the supply line.?.?[/COLOR]
Yes
gunns
#6 Posted : Thursday, January 7, 2016 1:07:02 PM(UTC)
gunns
So the heater is never under water?
gunns
#7 Posted : Thursday, January 7, 2016 2:39:22 PM(UTC)
gunns
OK denman... I don't know what happened, but....... I emptied the DW and took out the racks. I attached a rubber glove over the outlet for the middle spray arm to see if it was providing water and how much. I indexed the bottom arm and the top ceiling spinner. I ran a heavy/high temp wash. To my surprise both the lower spray arm and the top spinner had moved. The rubber glove was full of water. The second time I ran the same test the rubber glove was ripped. I then put the racks back in, placed a cutting board on the top rack to block the water from the middle arm and then placed four cups on top of the cutting board to see how much water came from the ceiling spinner. After indexing all three arm/spinners I again ran a heavy/high temp wash. All three sprayers had moved and all four cups were full to the brim with water. So..... All "seems" to be working. Go figure! I'm holding my breath as I suspect this is only temporary.
Guest (4)
