Hi everyone I've noticed lately that our Kitchen Aid dishwasher isn't releasing any rinse aid into the final rinse. Any ideas?
completed washer, but not heated dry
Here are your parts Parts for KitchenAid KUDC20CVSS3 Dishwasher - AppliancePartsPros.comRemove the dispenser from the unit. Manually activate the solenoid to see if rinse aid comes out. If not it could be that it is just clogged up. If yes. Check the solenoid for indications of overheating. Also check it with a meter should be in the 280 to 340 ohm range. If OK then odds are that there is a problem with the control board. |
THIS FORUM IS DEAD!!!!!!! |
