Looking for some assistance. Getting frustrated. Started about a 2 years ago, started getting error code FH. Was able to clear the code and no problems after removing debris from the pump. Would have same error code intermittently until about 2 months ago. Now FH error code is triggered when the wash cycle is started, about 2 minutes in. I can clear the code and the cycle will continue. The washer will fill with water and the tub will start to spin. Then about 2 minutes later the code will appear again and the tub will drain. I ran the diagnostic mode and noted it would give error code on C01. The rest of the diagnostics seemed okay. I checked the hoses and shut offs and have good water flow and no siphon issue. I had problems with the pump not draining completely. So I replaced the pump. I still got the error code FH. I checked the water inlet valves and noted that the valves did not seem to be shutting off and water would continue to fill and the ohms reading was not showing what I was told. At the same time I checked the pressure switch which seemed to check out at the time. So I replaced the water inlet valve. I still got the error code FH. So i tested the pressure switch again thinking it had to be the culprit for the FH code and probable overfill condition. For the life of me I could not tell if it was working properly. So I replaced the pressure switch. Still getting error code FH. So now I'm into this washer just under $170 with all of the parts. Can someone please help me figure out what the problem is before I end up spending another large amount of money replacing the flowmeter and CCU. What is the reading for the flowmeter and could this be the issue. Is it as simple as the flipping flowmeter or do I have a larger issue and need to replce the CCU. Please help.
