Slydini
#1 Posted : Wednesday, December 30, 2015 2:02:47 PM(UTC)
Slydini
Dryer would heat and run through cycle but the element would remain on. Now the dryer will not turn run but the element will heat no matter what position the timer is in. Replaced timer but it still does the same thing. Any help is appreciated.
#2 Posted : Thursday, December 31, 2015 12:44:48 AM(UTC)
Parts for Maytag MEDC400VW0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Check the thermal fuse on the blower.
Should be 0 ohms.
Also check the heating element.
Unplug the unit and both wires from the heating element.
Check the heating element, should be in the 8 to 12 ohm range.
Also check from each side of the element to it's case, both should be infinite ohms.
If not the element is grounded and should be replaced.
This can cause the heater to run all the time and unregulated so it may have blown the thermal fuse.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Slydini
#3 Posted : Friday, January 1, 2016 1:01:19 PM(UTC)
Slydini
Thank you denman. Following your advice, I tested the continuity of the thermal fuse. It appears to be faulty.
Guest (5)
