ImaAndrea
#1 Posted : Sunday, December 27, 2015 1:04:08 AM(UTC)
ImaAndrea
My fruit and vegetable bins fit into a frame with a glass shelf, I can't seem to figure out if there is a support missing as the frame is sagging away from the glass. I have looked at all the parts available online and cant figure out what is missing. The center divider is there. Is there something that holds up the frame that might be missing?
#2 Posted : Sunday, December 27, 2015 1:51:54 AM(UTC)
Here are your parts.
Parts for Amana XRBS209BWR / PXRBS209BW0 Refrigerator - AppliancePartsPros.com
I am assuming the frame is sagging at the fron /center.
I do not think that you are missing any thing.
Depending on how mush stuff is put into the crisper bins the frame sags over time.
Best to just replace the frame (item 14 in section 09).
The same thing happened to the frame of my fridge at the cottage.
I do not have a deli drawer under the crispers so was able to jiggery pokery a support from the bottom of the frame to the fresh food compartment floor.
You could do the same thing to the top frame of the deli drawer but over time it may also warp the deli frame and then you will have to buy two of them.
Another jiggery pokery possibility would be to make a couple clips (3 would probably be the best).
These would attach to the top of the frame and then over top of the glass.
The glass would then stop the frame from warping.
I have never done this so do not know if the combined weight of the food on top of the glass shelf and the weight of the food in the crispers could bust the glass.
