My wife said she bumped the cleaning button, and then immediately cancelled the cleaning cycle. The oven never reached 900° that would trip the sensor. The oven never even had a chance to get warm. I pulled the back panel and checked the wiring, and it all looks good. When I disconnected the latch from the motor I was able to move it freely. I wasn't able to turn the motor by hand... not sure if I should be able to, but it seems like maybe its seized up.
At this point how do I know what to replace? Seems like it would be the motor, but is there anything else to check?
Thanks in advance Tylan
I hate to bump this.... but does anyone have any ideas?
Here are your parts Parts for Frigidaire FEFL79JCB Range - AppliancePartsPros.comSee the attachment for the tech sheet. I am assuming that you have already unplugged the unit for several minutes to see if it will reset itself. I am not 100% sure but I think that rotating the motor manually would be very difficult or impossible because or the gearing in it. Below is a link to a manual which may help tou trouble shoot this further. You will have to join the site and be logged in to be able to download it. http://appliancejunk.com...&id=283;t=1450994048 |
THIS FORUM IS DEAD!!!!!!! |
OK, so it looks like most of the error codes in that guide point toward replacing the motor latch assembly. That's kind of what I thought... I read something similar elsewhere.
What's the EOC if it's not the motor? I'm guessing that would be the panel with the clock, that's the only thing that looks like a controller to me.
Thanks for your help!
Yes, I unplugged briefly... then again turned off the breaker for 10 minutes or so. No fix.
