tetuanrp
#1 Posted : Monday, December 21, 2015 8:45:11 PM(UTC)
tetuanrp
I have an Asko D5424, that recently has started giving me a F10 error. From the manual that's apparently a pump issue, and there is standing water when I open after the error occurs.
I emptied the water, went through all the instructions of cleaning the filters & the pump, and everything seems like it should be fine (I've done this 4 times). Even plunged for anything possible stuck in the line. When it's draining in the cycle I can hear water flowing, so I know the pump is working - but then I still end up with the error.
Any ideas?
