Addelliot
#1 Posted : Friday, December 18, 2015 4:21:40 PM(UTC)
Addelliot
Water dispenser stopped working so I checked the filter. Water Filter reset light was red. Filter hadn't been replaced for a year, so replaced it. Water still not working so disconnected water line at bottom of freezer door to see if water line was frozen. Assuming that was the problem I adjusted the temp in the freezer down for 24 hours to see if it would thaw the line. SUCCESS. However, water filter reset light still red when I press the rest button. Don't recall it being red before. Wondering what the issue might be. Or, if I even have an issue.
#2 Posted : Saturday, December 19, 2015 6:48:19 AM(UTC)
Parts for GE GSH22KGPAWW Refrigerator - AppliancePartsPros.com
Could be that there is a pri=oblem in the dispenser board.
Try holding the button for longer that 3 seconds.
Try pressing the button quickly.
You could also try unplugging the unit for a couple minutes to see if it will reset.
