My Kenmore stackable fills with about 3 inches of water then stops. If I open the lid it will continue filling. When it's full it will complete the wash cycle. I have replaced the lid switch and the water pressure switch. Neither solved the problem. Could it be the main board?
Since you have eliminated two of the three things that control the water valves I would say yes, the control unit is the next thing to change out.
