Parts for KitchenAid KTRS20MAWH10 Refrigerator - AppliancePartsPros.comSee the attachment for the wiring diagram.
[COLOR="Blue"]
Now there is a place on the refrigerator control panel to stick a screw driver and manually turn the defrost timer switch, activating the freezer defrost system manually. If I do this and the refrigerator defrosts allowing the refrigerator to cool, then wouldn't I know my problem was a bad defrost timer.[/COLOR]
I am assuming that"then wouldn't I know my problem was a bad defrost"is just a typo.
Because you would know that the timer was bad.
[COLOR="Blue"]Next, I would just replace it?[/COLOR]
Yes
[COLOR="Blue"]He never mentioned the evaporator fan which is mentioned in repair guides on this website.[/COLOR]
If the fan is running OK then it is not the problem.
Sometimes the frost can build up to the point that it interferes with the fan but defrosting the unit usually fixes this.
Below is my standard blurb on troubleshooting defrost problems.
First remove the evaporator cover in the freezer so you can see the coils.
If they are heavily iced/frosted over then it is a defrost problem.
Do not let them de-ice.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 4 in Section 03) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this without taking anything apart.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Section 05) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 35 in Section 05) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
