I have a GE profile serious dryer. I just replace the motor and heating coil they were one unit. The dryer turns and spins but I can't get it to heat up. I would love some suggestions on what to check for next? I just spent $140 for a new motor. Thank you, Todd
If you have an Ohm eter test the thermostats on the heater for continuity, one of those is probably out.
Nat
Were is the thermostat located on the dryer?
